Wheels An Tires
K1NGFR3AK
I have a 95 GT Conv...all suspension an such is stock...I have soem 19x9 03' cobra wheels on there now...Im curious to whats the largest Tires size anyone may have had on with out any adapters and or flaws of doing such...IF used adapters then please do state such...
I would like to keep all 4 the same size so able to rotate them out when needed be, but as well am not fully opposed to keep the fronts where they are and take the backs an extra inch or whatever may be..
Im thinking to get all four the widest I can, then on the backs use the 1"adapter bolt on spacers to give it that extra lil bit to fill the wheel well...
Win
Kennesaw, Ga
I have never seen a 19" either don't think they make them. If you want to go even all the way around just go with a 265/40/18. If you want a lower Profile just go 265/35/18. Your Choice. Then you could put a 1/2" spacer on the rear and be set.
ARdoller
-Never Forget-
adapters? I dont know what you mean by adapters, but flipping or removing the quad shock will provide plenty of clearance for a 315 tire, but you would want at least a 10" rim for that.
Late4Work
if u have 19's, then those would be the largest i have seen on a stang, that hasnt had a lift kit........i would say 18's and a small drop would look perfect
ARdoller
-Never Forget-
That should look good. Any more tire out back, and you'd probably start to bulge a little on a 9" rim.
K
K1NGFR3AK
sweeet...as well sorry about posting in the wrong spot " Paul "...as well again to all...Merry Christmas!
