where does this plug into?
x182dan
I have a 95 Mustang 5.0 that I am putting back together. I have a plug that I really do not know where it goes into. This plug is on the same harness as the injectors. At first I thought it plugged into the distrubuter as it did actually plug into it but after rethinking it how it was routed that way I realized that it didn't go into the distrubuter. There was another plug that went into the distubuter on the same harness. Now where does this other plug go into? Its the same exact plug that goes into the distubuter. As of right now my car is not getting spark and I think this plug might be it? I will probably get a picture of the plug tonight but I was hoping someone knows what I am talking about.
Thanks Dan
95 svt cobra
the only plug that i can think of that looks the same as the Dizzy plug, is the one that connects down by your oil press. sender. If its not that one is your coil hooked up? those are the only two plugs i can think of that would cause it to not have spark on that side of the harness. Pics would be VERY helpful
X
x182dan
Any idea what it plugs into by the oil pressure sender? The other day I had to soider in a new coil connecter because the previous owner ate up the coil wire because he put a tach wire on it and half of the strands were back. I mean the soider should have a good connection but I dunno. Should the coil wire get 12v with key on or only when I turn the motor over?
X
x182dan
I figured it out it plugs into a connector near the oil pressure sensor
