Which heads should I use?
jfor441
Ok... I have some NPI heads I can use and I also have PI heads I can use. My motor will be a high compression nitrous motor. I will be running a Snow Performance water-methanol kit. I will be sending the heads off to Modular Mustang Racing for their stage 3 head work. Need ya'lls opinion!
Black97GT
If you are going for high compression nitrous..seems like PI heads would be the obvious choice. Easier to make power out of them and will already give you a jump in compression to start with.
MustangMatt96GT
NPIs are better ported N/A
And since ur going to hae to do a shortblock anyway just run flat top pistons. NPIs n/a can out flow PIs ported the same way.
J
jfor441
Already have the shortblock finished with flat top pistons. NPI heads will give me 11.2:1 and PI heads will give me 12.2:1. Just trying to decide which set of heads to go with here.
For a power adder car-you need the extra exhaust flow that the PI's have over a NPI.
You can cram the air in with a SC or make your own air with N2O-then you need to get it out-so the better flowing exhaust port wins here.
JL
J
jfor441
JL
Thank you JL. That really helps my decision!
