Which oil will work best for my car
the.greg
Gastonia, NC
Hey guys,
I've had my 98 gt for a month now and I'm wanting to give it a tune up. I already replaced spark plugs and plug wires. Now I'm gunna do a oil change. I was planning on doin mobile 1 synthetic 10-30. I also heard good things about amsoil, but I cant find it at any of my local auto stores. My mustang is a 98 gt auto, with 138K miles on it. Do yall think this is a good oil choice for my car considering its high mileage. Thanks for the help, I'm new to working on my own car, and I appreciate the help.
moble 1 5W30 in winter 10W30 in summer always using a Napa Gold oil filter.
if you smoke out the exhaust, change over to a synthetic blend oil.
Amsoil makes a great product, but i personally prefer Moble 1 for motor oil and royal purple for everything else.
GDTrumbo
Nashville, TN
I'd do the 5W-30. Oil pressure at start-up is quicker and still has the shear strength of a 30 weight at operating temperature. It'll make a touch more power at the same time.
With the tolerances of these new engines, they don't want a slow "pump up". Make sure you get a correct filter with the anti-drainback feature, Motorcraft, WIX, etc. Some cheap filters don't have this.
GT
GDawg
I like Mobil 1 synthetic. But I use a K&N Oil Filter. It has the 1" nut built on it.
Change your fuel filter too and get a K&N Air filter if you don't already have one.
94 DropTop
I like the motorcraft blend oil, cheap and good shit. Here it is like 3-4 a quart compared to the 7-8 of mobile one.
fivepointnine
what about using 40wt or 50wt, I saw Castrol syntech 5w50 today.....for the hot summer months down here in the south?
ReplicaR
I've been using 10-30W regular fossil oil. Car has 172k miles on it, and seems to be doing pretty good with it, so I'll stick with it.
reduceallpain
I've been using Valvoline non-synthetic 10w30 with a champ oil filter.......
Next oil change I'm using Valvoline 5w30 non-synthetic with a wix filter.. Actually it's in my car now waiting to be changd...
vermilion
maryland
i use 10w30 syn blend or synthetic. i usually dont care for my stock engine. k&n or napa filter. now the new motor is going to be something else. :bootyshake:
JerZeyStangz
Northern NJ
Amsoil 5w30. I always tossed around the idea of 10w30 but your robbing a "touch" of performance when you put that oil in. I've used 10w30 before a handful times, and used 5w30 almost all the time, just stick with 5w30, and it definitely helps with gas mileage/performance. Just go with the manufactuer's recommendations, unless you have serious leaks present, I wouldn't touch 10w30 if you have mod motor. Pushrods, that could be a different story.
wytstang
5w and 10w is only the cold temp weight, they both reach 30w when the engine reaches operating temps (hot). 5w will reach the top end slightly faster then 10w btw.
Willis_98GT
DFW Texas
when i was npi i ran mobil 1 full synth 5/30
ever since my pi swap i've ran ams 5/30
my next change is coming up and dont really wanna spend the money on that oil again. so i'm considering something else.
