Which speedo gear?
07GtS197
Fort Myers, Fl
This is for my 87 Grand Marquis. Right now it has 4.10s and stock hight rear tires. I’ve run it through the calculators a few times and get a 21 tooth gear but its still 20% over the actual speed. The combo is an aod, 215 70r 15 tires and a 21 tooth speedo gear. It would be close to a fox with 28” tires, I don’t see fox guys having an issue so why do I? Am I doing something wrong?
Silver95bird
I recall something about there being 2 different output shafts. one with a 7 tooth gear on the shaft, and one being an 8 tooth. If a 21 tooth driven gear works in a mustang but not in that car, it may be the reason why.
Sent from my moto z3 using Tapatalk
07GtS197
07GtS197
Fort Myers, Fl
I’m starting to suspect the same. Maybe I’ll try the 23 tooth gear for fun, maybe it’ll actually work.
