Said f*** it. I built a many things in my life, might as well add a manual trans to my list. Started tearing it down after lunch.
Removed the shifter and roll pins from shift rods.
Then removed the tail and top cover.
Here is the top cover with a corner broken off. Should be an easy fix.
Then finished. Total of about 2 hours , but only cause I had to keep running inside to look at service manual on my pc.
Here is the damaged case. Jury is still out on rather it can be fixed. Need a bellhousing still.
BTW: All the parts, misc gears and shafts are separated into the coffee containers.
