Parts + Pics + Goodies
here r my trans parts, I got a whole 3550 trans in pretty good shape, a 3550 in pieces with busted input shaft, Lakewood blowproof bell and a Ford aluminum bell for the tKO500.. Sold the complete 3550 and aluminum bell, also sold my spare aluminum bell. I am pretty sure the lake wood bell wont need a backup.. LOL.. I got the Lakewood bell, good used case, good top case and some good internal spare parts.
Lakewood Bell (Got block plate with it):
Parts trans:
Cleaned up the 3550 case and ready to install TKO500 guts:
Reassemble reverse with all the needle bearings:
Main case assembled:
Finally Finished TKO500:
Now my trans is done.
What am I lacking to get it together? Just a cam, clutch , enghine gaskets and headbolt bushings..
Dropped the AFR heads in Favor of the TFS 170 heads. 58cc chamber , 2.02/1.60 valves... I couldnt resist a new set. It was cheaper then a used set. LMAO. Got some Comp Cam Gold 1.6 RR's for the heads. 7/16 stud..
Also to add to the parts list:
Full exhaust, BBK equal length headers, h-pipe with no cats, Flowmasters back to tips. I will be replacing those short fugly tips..
Along With the exhaust I picked up a Stalker hood. Not my fave SN hood but I picked this one up very cheap and I wanted it because its much taller then the other Stalker hoods I have seen..
Last but not least:
I got a Kenne Bell 1.5 setup for the project. I wont pick it up for 2 weeks but its paid for and bolts to the stock lower intake. Luckily, I already have a Stock lower thats been ported, welded up and ported some more. It wont flow over 215cfm max but with 6# of boost that shouldnt matter.
I am thinking that I might go with a custom cam for this setup. I really want alot more lift on the Exh side then the Int side , without using 1.7rr's on the Exh valves. Somewhere around .500 lift on Int side and .550 on Exh is what i am looking for. Really want more on the Exh but I will probably be close on PTV..
