White95’s ‘09 F-250 “Chiron”
Not entirely sure. If I wait to find and swap in a good ZF6 at the same time? Next year.
If I do the swap with the 5R110 and just find the rest on the side for later?
Couple months.. Leaning this way at the moment.
A manual Cummins is a ton of fun… but being able to stay in boost shifting, especially with a larger charger, is a big pro for towing, especially with a Ford trans that won’t explode lol.
white95
white95
Apex Junky
Prairieville, LA
I have a plan in place to rebuild the stock 5r110w. This calls for using better than OEM parts and finishing it with a aftermarket torque convertor designed for the Cummins power band. My timeline to pull the cab hasn’t been determined but should be within the next 6-8 weeks.
Beyond that? I’ll be sourcing the appropriate bell housing adaptor, engine mounts and accessory drive brackets as the logical next move. The notion is to take the necessary steps to get the 5.9 in place then replace the cab. New cab mounts will also be installed.
böde
