why is this POS still overheating?
98Warhorse
98Warhorse
Pharr, TX.
Gonna take a look at this thing tomorrow, i was hopeing the di-electric grease would help (thinking it was maybe a false contact causeing some sort of a short) but the car began to act up again today. i'll be going back to the drawing board and checking all things again, i never got around to burping the system so i'll do that tomorrow aswell.
Anyone got any tips on how to figure out if my water pump has failed on me? so far i havent lost any coolant and i dont hear any weird noises coming from my engine bay except for a squeeky POS aftermarket throw out bearing.
Just to refresh anyone jumping in on the thread who may have useful info and doesnt want to read the whole thing...
My car is operating completly normal, however my fan is turning off at odd times causeing the engine temp to go up. if the car is moving the engine temp will remain normal and not rise, however once i am idleing at a dead stop the engine temp will begin to go up. this does not always happen i have days where the car will perform flawlessly and then i have days where just after a few minutes the fan will shut off and i begin to overheat. I have replaced the Fan, Fan plug because the original plug was melting and i read that it is a good idea to replace the fan because the fan is what may be causeing the plug to over heat. I have also replaced the fuse, and thermostat so far for good measure.
If anyone has any experience with this issue please feel free to chime in, any info is appreciated.
Help me Obi Wan Kenobi, your my only hope.
FrankenStang
bum****egypt
i sat here thinking for a min and did a little reserach...all i came up with was 1st flush your cooling system..you may have a clog some where in ur radiator that is causing it it to sometime overheat and some time not, maby becase the possible contaminant gets to a spot where it will clog and then to a spot where it wont...and then when ur done flushing it you can also burp the system and eliminate that as a problem..easiest way to fill the system and have less bubbles is to park on the steepest hill you can find rear, trunk towards the bottom and full it up so the air bubble travel up...or just sky jack ur front end of the car off the ground....good luck
