why is this POS still overheating?
98Warhorse
Pharr, TX.
Replaced thermostat, fuse, fan plug and fan. Is there something I am missing? I'm gonna re check the wireing when I get home but I just need to know if there is anything else that might be failing on me that I don't know about.
Any help is appreciated.
sn95jones
Arlington, Tx
Maybe the water pump, but before you go back out and try working on it again I'd recommend taking a chill pill before you make shit worse on your car by breaking something out of frustration
BLCKSTNG96
did you replace the fan on this car? i have had quite a few of these cars and a number of them have had intermittent fan issues.it seemed it worked but it wasnt really working all the time and not to full potential,also why the plugs begin to melt and stuff.
98Warhorse
98Warhorse
Pharr, TX.
My original plug was melting so I got a new one from the ford dealer and replaced the plug. I also went ahead and replaced the fan because I read a faulty fan is what causes the plug to melt. The car is heating up at a dead stop and cools down once were moving cause I'm getting air flowing through the radiator while moving.
Keep in mind. Just redid the wireing and fan last night. I'm going to check the wireing and add some gel that a buddy of mine told me to use to prevent corrosion and help with the plugs contact.
The water pump has less than a year on it and I don't have any water missing so a head gasket or pump is unlikely. I just wanted to make sure I wasn't missing any sort of relay or switch of some sort.
sn95jones
Arlington, Tx
A water pump can fail prematurely. Just because it's only a year old doesn't mean it's bullet proof. And you don't have to be missing coolant to have a bad water pump. It could have seized up, not all parts are going to be perfect.
Tony
ohio
maybe a radiator flush, could have an air bubble....bleed and flush may help??
98Warhorse
98Warhorse
Pharr, TX.
I hear ya, I just wish there was a more accurate way to tell whether its gone bad or not. I'm not ruleing anything out I just assume its less likely to be the culprit.
Tony
ohio
like me ruling out bad tire with steering wheel shake, lol! replaced every fn thing connected to the dam spindles and what do ya know.....bad tire:mad:
RichV
CO
Does the fan run? Should be able to hear it turn on in idle.
Does it run in the right direction? It should pull air, not push.
sn95jones
Arlington, Tx
Look on the bright side Tone atleast you won't have to replace any of those parts anytime soon :p
greenscobie86
The Big Apple
My neighbors Expedition acted similarly. We threw a new stat and coolant in it only to realize the water pump had taken a shit. Its not too hard to take out on our cars, just give it a looksee.
1997gtRioRed
lol i "balanced" my friends tire for him once with about 8 oz of wheel weight on the inside of his driver front rim. hehehe thats what you get putting a gay pride magnet on my car
98Warhorse
98Warhorse
Pharr, TX.
yes the fan runs and correctly, i didnt get a chance to get to it today but it ran fine the whole way home. gonna give it another look tomorrow morning.
Shifty Powers
Where the wild goose grows
Could be a bad t-stat. I had to go through a few of those on my other ford before I got one to finally work. Also dont our cars have fan switches?
And I wouldnt rule out a water-pump man. Have a 94 mustang gt(i know diff engine) but in the past year we have done about 4 water pumps on it. Needless to say it did not like aftermarket companies.. just did an oem one on it and hopefully that fixes the issue..
So until you fix it.. dont stop! just blow all red lights.. lol
and also like someone said. Burp the system. Could be an air bubble in there somewhere..
BLCKSTNG96
i saw you mention other relays or whatever u may be missing.the ccrm box controls the fan also. start the car and turn on the ac to high,fan should come right on
FrankenStang
bum****egypt
just double check ur fan is working...heat it up and pop the hood and see if its running, although you should hear it from inside the car even..also try burping your cooling system and while its running give ur upper rad hose a squeeze and see if it has good pressure in it.
98Warhorse
98Warhorse
Pharr, TX.
Thanks for all the help, I'm deffinatly gonna try burping the system. Hopefully I don't have any kind of leak anywhere, I've been away from home and the car for a few days so now I'll get back on it with a fresh set of eyes
