Will a bbk 255lph fuel pump work?
cody0170
Stevo said:
A 255 comes with the procharger kit. Along with the injectors. And drive very careful to tuners. DO NOT go into boost. Are you gonna install it yourself?
voidfinger said:
i'm sure you will get an answer but i hope its an answer you will like, Also, i read that you have done the pi swap... you do know that your compression is 10.5:1 and that is pushing it for a blower. your getting it trailered to a dyno and getting it tuned before your starting it up right??? b/c i wouldn't even bump it over with that much compression and boost...
im thinking of doing a pi swap... i didnt know you could get it tuned and be ok with out getting dished pistons. what will the tuner be able to do
cody0170
Scarface said:
tuner can add fuel, and adjust timing to allow for the higher compression.
so that being said i could use pi heads and still supercharge it and be safe. how much boost could i run with a stock bottom
voidfinger
i've read that with the 10.5 : 1 CR the boost is snappier on a centri. the lsx motors have higher compression too so yea, its doable but i wouldn't get to much boost... like scar said 8 max
voidfinger
Scarface said:
the avitator is around 170, the svt focus is around 80. Then there is the GT supercar pumps....
So i should jump on that 170 frpp pump that 8psi is selling then huh.
ripper
Did you buy the kit or a used s/c? If your doing the install I will give you one very good piece of advise. Be absolutly sure you install it as a pull thru MAF. Not a blow thru. If you install the MAF after the s/c your tuner will run away, or even worse you will never get a good tune. Believe me on this one. The very best install is to use a Powerpipe and install the MAF right behind the K&N filter in your wheelwell.
cody0170
see it seems more practical to find a cobra motor and start there with 300-390 hp factory
C
chris98gt
yes it was used about 4k miles on it, I had planned on setting it up like the manual said to. I also wasn't plannin on just fireing it up and raising hell. I only live 20minutes from mph so yea it's no big deal to wait to get it tuned.
voidfinger
How does the kits come? with a blow thrU?
