Jan 10, 2018 #1 A_+ Active Member Joined Apr 30, 2013 Messages 297 Reaction score 11 If it fits, will any battery work on a 95? I found some cheap ones at a local parts store but the CCA is a lot higher than what is recommended.
Jan 10, 2018 #2 evilcw311 Most Evil Member! SN95 Supporter Joined May 9, 2010 Messages 7,456 Reaction score 2,136 Location Louisville, KY As long as it fits properly as the terminals are correct. You need to make sure that it will fit in the clamp and not touch the hood. Other than that you should be ok. Sent from my iPhone using Tapatalk
Jan 10, 2018 #3 OP OP A_+ Active Member Joined Apr 30, 2013 Messages 297 Reaction score 11 All I needed to know. Thanks!
Jan 10, 2018 #4 ttocs Post Whore Joined Oct 9, 2009 Messages 32,663 Reaction score 5,669 Location Evansville Indiana you can get too small of one but bigger cca's is better.
Jan 10, 2018 #5 OP OP A_+ Active Member Joined Apr 30, 2013 Messages 297 Reaction score 11 The one I have my eye on is 7xx CCA. I’m gonna check it’s measurements tomorrow to see if it fits. I hope it does
