AaRoN
King Post Whore
Should I repair it? Should I replace it?
Modern technology makes it possible to repair windshields that would have previously been scrapped. Not only does this save your windshield, it also saves you money.
But be aware that even the most advanced glass repair techniques have their limits. So if your windshield is severely damaged, new glass may still be in your future.
Do I have to replace my windshield or can it be repaired?
Windshield repair or replacement depends on the size, location and severity of the damage. The majority of windshield repair shops can repair quarter-sized rock chips and cracks up to three inches long. Anything bigger and most places will recommend replacement.
However, some facilities use a special technique that allows them to repair cracks up to 12 inches long. So it pays to check around before committing to a new windshield.
Location of the damage also plays an important role in determining your windshield's fate. Cracks at the edge of the windshield tend to spread very quickly and can compromise the structural integrity of the glass. If they're caught in time, they can be repaired. But in most cases, it's usually advisable to replace the windshield.
Also be aware that some facilities may not repair a chip that appears directly in the driver's line of vision. Because the repair process leaves minor distortions in the glass, some shops prefer to replace the windshield rather than compromise the driver's vision.
Regardless of the size and location of a chip or crack, it's always advisable to have it repaired quickly. If you wait some time to repair it, dirt can work its way into the damaged area, affecting the effectiveness and clarity of the repair.
Finally, bear in mind that if your windshield took a big enough hit, it may simply be beyond saving. Major impacts (BIG objects) or accident damage go beyond what any repair facility can fix. In these severe cases, replacement is a must.
How much will this cost?
Repairing a single rock chip costs around $40-$50 for the first chip, then usually $10 extra for each additional chip.
However, if the crack is longer than three inches, it may require special treatment. Long-crack specialists typically charges about $70 to repair a six- to twelve-inch windshield crack.
Windshield replacement costs considerably more and varies greatly depending on the vehicle. In addition to the cost of the windshield itself, a windshield molding kit and installation labor must be factored into the overall replacement cost.
The difference in cost between a dealer price and an independent glass shop is usually due to the actual glass used. Dealers often charge more because they're using an Original Equipment Manufacturer (OEM) windshield, which is exactly the same as the one that originally came with the car.
Meanwhile, local automotive glass shops typically use windshields from non-OEM suppliers. This glass is usually less expensive, but offers quality, safety and clarity similar to the more-expensive OEM windshield. Non-OEM glass is required to meet or exceed the same safety standards as OEM glass.
However, all the glass shops surveyed strongly advised that only OEM-recommended sealers and adhesives be used during windshield replacement. Use of inferior quality urethane could result in the windshield leaking or even becoming dislodged in an accident.
Where do I get the work done?
When it comes to repairing or replacing your windshield, you have a number of possible options. It all depends on your specific needs.
* Automotive glass specialist. These facilities specialize in the repair and replacement of automotive glass. This includes not only windshields, but also side and rear windows. Most usually attempt to repair a windshield before recommending replacement.
* Windshield repair facility. These independent and nationally franchised shops usually specialize in windshield repairs only. They fix chips and cracks, but do not install new windshields.
* New car dealer. Your local dealer can replace your windshield with an original equipment manufacturer (OEM) windshield. Many dealers sub-contract to mobile glass services, who come to the dealership and replace windshields on-site. Sometimes non-OEM windshields are also available through dealers.
* Mobile glass repair and replacement service. Rather than go somewhere to have work performed on your car, these services come to you and repair or replace your windshield wherever your car is locatedâ€â€at home, or even at work.
* General glass service. In addition to replacing automotive glass, these facilities also handle sales and installation of commercial and residential glass.
The windshield services listed above can be found in your Yellow Pages under Glassâ€â€Auto or Windshield Repair.
Is this covered by my insurance?
Windshields are covered by all of our automotive insurance companies. But because the cost to replace a windshield is so much higher than repairing it (four to ten times higher), coverage is handled differently for replacement vs. repair.
If you're replacing a windshield, your insurance company will ask you to pay your deductible and they'll pay for the complete replacement.
However, if you're repairing the windshield, the deal is a little sweeter. Having recognized that it's more economical to repair a windshield than replace it, our insurance companies may waive your deductible and pay for the entire repair.
This arrangement encourages customers to repair their windshields rather than replace them every time they're chipped. It also represents a substantial savings to both you and your insurance company over the lifetime of your policy.
Have a qualified glass specialist carefully examine your windshield to determine whether a repair will suffice or if it should indeed be replaced. Also remember to check with your insurance company to confirm the terms of your coverage before committing to any windshield work.
How does windshield repair work?
Windshield repair involves injection of a special resin into the damaged area using a tool that attaches directly to the glass. Once injected, this resin is then cured and polished to restore the clarity and strength to the glass.
When a chip or crack occurs, it often spreads into the windshield's inner layer of plastic, which is sandwiched between two layers of glass. In some instances, a drill is used to make a clean passageway to the plastic, where the resin is injected to repair the damage.
Think of a windshield repair as first-aid that prevents the damage from getting worse. In some cases, it may look nearly perfect, while in others, it could still appear slightly blemished. But in either case, a proper repair prevents the damage from spreading.
And since every chip is unique, some will respond more effectively to repair than others.
