WMS Cold Air
ranger50toy
If that's all there is, save your money. The bend right before the MAF sensor is a hit or miss item and you will still be using the "ribbed for her pleasure" factory tubing.
stang94X
a lot of people say that the c&l mass air flow sample tube for 30# injectors isnt good but mine has worked perfect and is awesome but your probably not looking into that, i figured i would just it, but if you just want the cai and the true flow pipe, it is f'n great, its an huge filter that goes on your mass air and flows really good and the true flow pipe is made of cast aluminum and works great and looks sweet, i actually gained a few numbers from just the filter and pipe, i had the mass air and when my car was getting tuned i bought the c&l true flow kit and i had my tuner switch it out half way through when i had the custom dyno tune done
Schiffy
Norfolk, Va
I am a firm believer in my JLT Cold air intake... it looks good, has the basic principles built into it, quick install, and under $200. I love it, and it looks good! You can get them in plain white, or custom painted to body color, or even have flames or designs painted on it.
stang94X
Matt94GT said:
cobra30294 said:
I hate rubbers! Thanks. what about C&L solution?
http://www.cnlperformance.com/76mm_94-95cobra.html
wow for some reason I dont believe those gains?
i had mine switched from a BBK cai to the C&l trueflow kit and gained a few hp to the tires, but as i stated above i also had the c&l maf already on it, but then again every setup will also very in numbers with what you have done to the motor
