Gt 500 rotors and s197 GT calipers install.
alex302
As some of you know I bought a unfinished 91 turbo 4cly Fox project that has some really nice parts, the plan was to finish it but I decided to part it out. The fox came with this brake setup and 18" fr500 so wheels and brakes are now on my 95 Gt.
The shop that was building the fox made a custom CNC bracket for sn95 spindles to work with the s197 brakes.
Had to do a little grinding to line up the bolt holes.
Here's a pic of the caliper bracket installed with out the rotor.
14" rotors.
Good clearance between rotor and bracket.
I used some washers as spacer to line up the caliper bracket.
08 GT calipers.
The brake line on the passenger side need an adapter from 7/16 to 3/8.
CC'S95GT
Hampton ,Ga.
looks great. have you tried them out yet? Is the stock MC going to be able to handle the added fluid needed?
alex302
alex302
They feel great. When I did my motor swap I switched over to a hydo boost setup out of a 04 Mach 1, so the MC is good.
KillNThrill24
Cleveland Ohio
what a difference in size, thats a great swap especially for the extra power you have from your 4V. a question that doesnt exactly pertain to the brakes though.. whats with only 4 lugs on the wheel lol? thats not the first time ive seen that on a mustang and ive always kinda wondered why i see them with 4 lol
alex302
alex302
Hahahaha I was waiting for someone to say something about the lugs, don't know about other stangs but for me is I had locks on it an I lost the key and I have not replace them yet.
white95
Apex Junky
Prairieville, LA
Way cool!! I sent that shop a message about building more of those adapters. If you ever drop in there, you should also inquire. I bet we could get several members here together for a group buy.
alex302
alex302
I emailed the owner of the shop to see if can make more. I may have to drop off my car so he can reproduce the bracket.
Are the adapter brackets aluminum???? That's scary. :)
Who makes them? It's a cool upgrade, not sure I trust the aluminum, specialy for track use. Those old duralast brake pads looked very well heated, you may want to upgrade them to some thing better than part store pads.
alex302
alex302
The brackets are CNC billet and are super beef plus the way I see it the the 6 piston brembo calipers and brackets on cobras and gt 500's are all aluminum. The brackets where made by local shop called S&R Performance,as for the duralast pads that was the old stock brakes.
MustangChris
Aurora, CO
sad to hear youre parting out the SVO :-(
nice brakes, tho! Those rotors are HUUUUGE!
alex302
alex302
They are big :). I'm trying to fine a new home for the fox I really don't want to part it out I still want to see it done.
94-5.0GT
I would be interested in a set of them brackets. Let me know. but it looks very nice. Was the hydroboost pretty easy to swap in?
alex302
alex302
The hydro swap was not bad I had to drill some of the mounting holes, I don't know how the swap would work with a pushrod 5.0 due to the different PS pump.
Latvik
Resurrection bump.
Anything ever come out of this? I would be interested in buying a pair of those adapters.
Suprasuavy
