Anchor-Room
- Joined
- Mar 28, 2011
- Messages
- 286
- Reaction score
- 4
>>> CLICK HERE FOR PICTURES <<<
~~~ (Search Feature at bottom of page) - CLICK HERE FOR SPECIALTY PARTS ~~~
If you have any questions, please do not hesitate to contact me directly:
Jason - 757.641.7829, [email protected] / www.anchor-room.com
Updated: October 9, 2011
Under the hood
... >> Complete '03 Cobra Motor (50k miles) & 2.2 Kenne Bell, T56 Trans. W/Mc Cloud Clutch ( x 1 ) $8,500
... ABS Hard Lines (front of car) - Stock ( x 1 ) $110
... AC Accumulator - Stock ( x 2 ) $35
... AC Compressor - Stock ( x 4 ) $185
... AC Lines & Manifold (3 Lines 19835, 19972, 19D742 & Manifold 19D734) - Stock ( x 2 ) $270
... Alternator (rewound to 185 AMP! - **NEW**) - Stock ( x 1 ) $245
... Alternator Bracket - Upper - Stock ( x 1 ) $55
... Battery Cover - Carbon Fiber - Series 58 - AM ( x 1 ) $95
... Battery Cover Series 58 - AM ( x 1 ) $25
... Belt - Accesory - Stock ( x 2 ) $10
... Belt - Bando 8pk1930 - AM ( x 1 ) $15
... Belt - Motorcraft - 2R3Z - 8620 - BC - Stock ( x 2 ) $20
... Belt - Napa MicroV AT - 080780 - AM ( x 1 ) $20
➫ Belt Tensioner & 100mm Pulley - Metco - AM ( x 1 ) $120
... Bolts - Alternator - Stock ( x 3 ) $20
... Boost hose cluster Complete - Stock ( x 1 ) $90
... Bolts - Exhaust manifold bottom studs (NEW) - Stock ( x 2 ) $10
... Bracket - Side of blower (with accessories) - Stock ( x 1 ) $55
... Brake (pressure distribution) Block - Stock ( x 3 ) $40
... Canton Windage Tray (All Ford 4.6L/5.4L) - **BRAND NEW** - AM ( x 1 ) $50
... Caster/Camber Plates (2) - Stock ( x 2 ) $40
... Clutch Cable - adjustable - AM ( x 1 ) $50
... Coil On Plug Covers - Stock ( x 1 ) $75
... Cruise Control Module cable (**BRAND NEW**) - Stock ( x 2 ) $35
... Cruise Control Module (No cable & Bracket) - Stock ( x 4 ) $75
➫ >>Eaton M112 -Super Charger - w/2.76 pulley - Stock ( x 1 ) $400
➫ >>Eaton M112 -Super Charger - w/stock pulley - Stock ( x 1 ) $350
... EGR sample tube - Stock ( x 1 ) $5
... EGR w/Tube & hoses - Stock ( x 1 ) $45
... Engine Wiring Harness (FI, Cops, Etc.) - Stock ( x 1 ) $195
... Evap Unit w/hoses - Stock ( x 4 ) $100
... Expansion Tank for Radiator w/cap - Stock ( x 3 ) $45
... Exhaust Headers - Stock ( x 1 ) $40
... Fan Assembly - Stock ( x 1 ) $130
... Filter (Air) Housing and tube - Stock ( x 1 ) $90
... Firewall Heater Hoses - Stock ( x 1 ) $75
... Fuel Evap Lines - Stock ( x 3 ) $75
... Fuel rails - Stock ( x 2 ) $40
... Fuel regulator - Stock ( x 2 ) $10
... Fusebox Bracket - Stock ( x 3 ) $20
... Guides, Tensioners, Gears, Chains - Stock ( x 1 ) $195
... Harmonic Balancer - Stock ( x 2 ) $180
... Headers (Bassani) - AM ( x 1 ) $395
... Heat exchanger - Stock ( x 5 ) $85
... Heat Exchanger hoses (3) - Stock ( x 1 ) $25
... Hood release latch and cable - Stock ( x 2 ) $30
... Horns - Stock ( x 2 ) $25
... IC pump hoses - Stock ( x 1 ) $30
... Idler Pulley - Grooved - Stock ( x 2 ) $22
... Idler Pulley - Smooth - Stock ( x 11 ) $12
... Intake 90* Elbow - Rubber - AM ( x 1 ) $10
... Intercooler (under blower) - Stock ( x 1 ) $375
... Intercooler hoses - 2 - Stock ( x 1 ) $30
... Intercooler overflow Cap - Red - AM ( x 1 ) $10
... Intercooler reservoir - Stock ( x 4 ) $45
... Intercooler Reservoir Cap - Stock ( x 1 ) $10
... Latch/Radiator front support - Stock ( x 1 ) $20
... Latch/Radiator front support bar (only bar) - Stock ( x 1 ) $5
... Lower hose to oil cooler - Stock ( x 1 ) $15
➫ Maf - 90mm - Stock ( x 1 ) $60
➫ Maf - SCT BA2400 - AM ( x 1 ) $195
... Master cylinder/booster - Stock ( x 2 ) $195
... Master cylinder/booster/lines - Stock ( x 1 ) $295
➫ Oil cooler/tube/filter assembly - Stock ( x 1 ) $400
... Oil seperator - AM ( x 1 ) $20
... Oval Throttle Body Clamp - Stock ( x 1 ) $5
... Power Steering Pump - Stock ( x 1 ) $100
... Power Steerring Fluid Reservoir - Stock ( x 2 ) $65
... Power Steering Fluid Reservoir Bracket - AM ( x 6 ) $100
... Power Steering Fluid Reservoir Bracket - Stock ( x 2 ) $175
... Power Steering Fluid Reservoir Cap - Stock ( x 1 ) $5
➫ Pulley Bridge (no tensioner) - Stock ( x 2 ) $275
... Radiator Support Brackets - Stock ( x 2 ) $15
➫ Red Line Tuning Hood Shocks **NEW**FREE SHIPPING** '05-'11 Mustang - AM ( x 4 ) $80
... Rubber Seal, Cowl - Stock ( x 4 ) $15
... Sensor - Crank Position - Stock ( x 1 ) $25
... Sensor - FRPS - Stock ( x 4 ) $50
... Sensor - (IAT) - Stock ( x 1 ) $20
... Sensor - IAC - Stock ( x 1 ) $75
... Sensor - TPS - Stock ( x 1 ) $25
... Starter - Stock ( x 3 ) $75
... Steering Shaft - Stock ( x 1 ) $75
... Strut Tower Covers (2 NEW) - AM ( x 1 ) $10
... Supercharger Plenum - Stock ( x 3 ) $65
... Swaybar Links with bushings - Stock ( x 2 ) $15
... Tensioner (w/pulley - 8 RIb) - Stock ( x 2 ) $50
... Tensioner (w/pulley - 6 Rib smooth) - Stock ( x 1 ) $50
➫ Thermostat Housing (!!BRAND NEW!!) - Stock ( x 1 ) $108
... Throttle Body - Stock ( x 4 ) $95
... Throttle Body Clamp and rubber gasket - Stock ( x 1 ) $10
... Timing cover - Stock ( x 1 ) $215
... Transmission Wiring Harness - Stock ( x 1 ) $100
... Upper Idler Bracket & Pulley - Stock ( x 1 ) $75
... Valve Cover Gaskets - Stock ( x 1 ) $9
... Washer Reservoir - Stock ( x 2 ) $30
... Water Pump - Stock ( x 2 ) $55
... Wiper Arm Assembly (Under cowl) (Both) - Stock ( x 4 ) $37
... Wiper Motor - Stock ( x 4 ) $35
Under the hood
