04 cobra Questions.
MustangChris
Aurora, CO
hey all.
I need some help on my terminator.
lol.
so, here are a few of my questions:
1) What vacuum do your cobras idle at? (Mines at 18 in/hg)
2) My car drops from 12 PSI to 10 PSI of boost, I was told this was a boost leak, but I was also told this is common on Eatons to do so at higher RPMs. Should I start hunting for a boost leak?
3) What is your oil PSI at? mine ranges from 30 PSI at temps to 85 PSI when cold start up. (At one point it topped my 100 PSI gauge...)
4) What are some signs of high crank case pressure on these cars?
Thanks All!
-Chris
justinschmidt1
All those things sound normal, you would have oil blow by if you had excess crank case pressure
100psi of oil pressure??
Remember my oil pressure issues. Seems real high.
sounds like your using digital gauges? I am too and every once in a while they will read some crazy peak number(high/low) either from a power surge or loss or just a dirty signal. One day I checked the peak reading on my engine temp and it said it was 586 or something crazy like that.
whoah, uncl Matt, what's up man!! haven't seen you for a long time. how's life.
98mstanggt
Louisiana
I think this is normal at least I've seen it a few times and I think it depends on your setup also. It could be your belt, maybe its the gauge, could be the rings etc etc I'm running 15psi with my ported 03 cobra and mine stayed at 15psi the whole pull so I'm not really sure. Make sure all your vac lines are tight mine seem to loosen/come off every now and then.
JeremyAlan
SN95 Supporting Member
Suffolk, England
1) i'll check mine
2) when does the boost drop happen?
3)i've never checked mine lol
4)no clue lol i have a breather on my pass valve cover and a vac line on the driver side
vermilion
maryland
chris, you could be a tad bit rich on the tune at idle. mine sits at 14-15hg at idle during vacuum. however, i don't use pcv system. modulars have tight clearances on their bearings but still usually 20-25 idling and 65-72ish at cruise RPMS. do you have a wideband? meter your AFR.
98mstanggt
Louisiana
O yeah, you got a thread about this on svtp. Now that I see your blower in your sig, I honestly didn't even know they could be swapped and/or that could produce those numbers.
Could be this too ^
MustangChris
MustangChris
Aurora, CO
wow. this thread came back to life. lol
anyways, the boost drops from 4,500 RPM down to 6,000 RPM (continues to drop after that, but thats when it levels off at 10 PSI again.)
it has a nice, "hump" shaped boost curve:
10PSI @ 2,750
11PSI @ 3,000
12PSI @ 3,750
12PSI @ 4,500
11PSI @ 5,000
10.5 PSI @ 5,500
10PSI @ 6,000 - 6,300
drop off (close throttle) @ ~6,400 RPM
MustangChris
MustangChris
Aurora, CO
i have two widebands B-)
they aren't well grounded at this time (autometer tech support thinks) so they read lean. Put the car on the dyno yesterday and it's actually running rich. lol.. . . .. .
MustangChris
MustangChris
Aurora, CO
im going to replace the TPS and IAC when I send off the TB to accufab for rebuild.. . ..
just have to get the DD up and running. lol.
JeremyAlan
Suffolk, England
Meh, I didn't like my accufab. They put the cruise control mount in the wrong place and it causes a delay in the cruise engagement.
