13" Cobra Rear Brakes... Coming soon!
Pete@FTR
Preferred Vendor
Rocklin, CA
I've been getting blasted with people asking for this, since I've hinted at it before. We're on the home stretch.. putting this into testing as soon as I can get the car apart. 13" Cobra front brakes mounted to the rear.
The main issue that could potentially arise is piston knock-back due to the floating C-clip axles, so the main function of our testing will be to make sure that this will not be a problem. Based on the measurements and math I've done so far, we'll be in the clear, but testing always tells the full story. Edit: Turned out not to be an issue! We're in the clear :)
anyone wanting a dirty/used pair of calipers for cheap that they can clean up and do this with pm me.
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
Will it work with irs? E break?
Theres been a lot of interest in the IRS version so its definitely #1 priority once the SRA version is complete. We're already working on the IRS bracket.
No cable e-brake, you'll want to use one of these: http://www.jamarperformance.com/Online/catalog/products.php?56 I'll be testing it myself
What size rotors? Will the brake bias have to be adjusted?
13". Will be doing testing as far as the bias goes and get back to you.
Pleasanton/Hayward, CA
rz5.0
Great state of TEXAS
Interested.. Need too do more research on the e brake.. I think i seen kits that use another brackets to mount a different caliper for e brake.. Thanks I'll keep an eye I on this
Sent from my LGLS991 using Tapatalk
OMG PETE IF YOU CAN DO THAT IT WILL BE SOOOOOO TITS LEGIT!!! Cobra twin piston AND THE SINGLE PISTON?!?!?!?
:lewx4:
Willwood makes a single piston add-on for e-brakes but it would be another mounting point to engineer into it.
rz5.0
something like this.. I believe this is a bolt on kit for the Panoz but works on the irs mustang..
wmfateam
Gilbert, AZ
Do people not use the trans to keep it from moving? Good old Arizona with all of the flatness. And most race cars remove the e brake.
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
My thoughts exactly... I've given up arguing that e brakes are practically useless
well now yes some cars are not meant to be parked and only driven on flat ground, ect. And then there are the other %95 of us.....
DKblue98GT
Seems like my car is always parked on an incline. Some sort of E brake is a must for me. I have an extra set of Cobra calipers in the garage and would love to put them on the rear of the Cobra.
jeanfltns01
