1983-1988 Ford Ranger air deflector install
Maximum95
Albuquerque, New Mexico
I was writing my build thread, and had a question from @joemomma
How often does that Ranger air deflector scrape? I like the look of that - have you detailed the install anywhere?
I told him I would do a write up next time I had the car in the air. Which thanks to my leaking T5... I did! So, I'm here to share some photos of how I installed an '83-'88 Ranger air dam on my SN95.
The whole project started because I noticed my cooling fan engaging while driving on the highway. I did a little research and found out just how important that little factory air deflector is (my car was missing it). The SN95 and many other '90s cars with tiny grille and bumper openings rely on some type of air deflector along with openings in the bottom of the bumper for cooling.
When travelling at speed, the air deflector generates a high pressure zone in front of itself, which causes a low pressure zone behind. This effect draws air up and over the radiator. Even those little 1" deflectors that come on the SN95 are essential.
Because I do a ton of highway driving, I decided to go a step further. I went and got a Ranger air dam from the junkyard and mounted it in place of the factory one. This made a HUGE difference in cooling. My fan only ever engages if the car isn't moving. When driving around town at any speed over 35mph, you can just watch the temperature gauge go down. Even at 120mph+, bearing down on the throttle, the coolant temperature never gets over 200°. I would recommend this to, well, everyone!!!
For starters, here is a photo of the part and the part number. E27B-10001A06. I haven't washed the car recently and this thing catches ALL the bugs.
Once you have the part, it is necessary to grind down the ribbing that comes onto the top. I don't have a before photo, but this is how it should look after you cut them off. I used an angle grider with a sanding wheel. Doesn't take long at all.
I held the air dam up to the radiator support, and marked the locations of the 5 holes in the middle. The center hole on the air dam was lined up with the center clip hole for the bumper cover. I then drilled the holes and installed 1/4"-20 nut serts.
Here it is installed. You can see the location of the machine screws holding the air dam and bumper cover, instead of the plastic clips that usually hold the bumper cover.
When the car was lower, I used the same part but trimmed down. If you don't like how far down the deflector is, that is always an option too. Here is the shorter version.
Here's how it sits now. I hope this helps someone out there!
I have told that same thing to so many people that have problems with temps while driving and they must think it is black magic/bs.
Man. I love this idea, and just spent my lunch break looking for one. Apparently they are discontinued for that model now.
joemomma
Found a thread over on corral there they used the lower trim from an Explorer, no luck finding one of those either.
Maximum95
Maximum95
Okay so I actually need to head to the junkyard to get some fender liners for my car. I'll see what I can yank, these trucks still show up down here. I'll let you guys know if I find some!
Maximum95
Maximum95
LMC RANGER TRUCK
@RAU03MACH is correct!! Looks like LMC truck has them for cheap!! This one is a little different from the one I installed. I also have one of these here in the garage. I can check if it fits. I got it for my Cadillac but haven't done anything with it yet.
badass98svt
My car was missing the air dam, so I installed an OEM replacement. Available at LMR.
Maximum95
Maximum95
I put the '89-'92 piece next to the '83-'88 piece on my car. The newer one is quite a bit wider. It might be difficult to fit on a Cobra bumper, but should fit a GT bumper. A few photos for comparison.
white95
Apex Junky
Prairieville, LA
Haven't gotten my mitts on a Ranger deflector yet but, for the time being, installed an OEM replacement version. Pretty sure it made very little, if any, difference.
It’s cute though :D
Wonder if I need to construct the pan that ties into the core support like this to channel air:
