2002 Trans Am Collector Edition
g36 monkey
g36 monkey
Orlando, Fl
Not much of an update, but I took the car to get the Sinister boxed subframe connectors installed the other day. Fairly straightforward installation, and they really beef up the mounting point for the front of the rear lower control arm.
We’ve not really driven the car enough to notice a big difference, but I’d like to think it handles better. The ride seems less jarring, but that will probably get much better with new shocks and springs. Either way, I’m happy to have a great place to jack the car up the whole way down either side of the car! Anyhow, just a couple shots of it on the lift. Will try to get better pictures later (when I install the lowering springs).
Thanks for looking!
01yellercobra
I saw this on Instagram.
g36 monkey
g36 monkey
Orlando, Fl
Alright so it's lowered:
The sway bar end links snapped when I took them off (looked original) - so I have new some new ones to install my next day off.
I didn't install the lower isolators, I may come to regret it. Hopefully it's not an issue.
Getting the original shocks disassembled was miserable. One the nut was completely seized, the other we could not get the shaft to stop spinning. The spinning one we used a hack saw to cut the shaft in half to release the top portion. The other one we used a cutting wheel on a Dremel to cut the nut off, hit it with a hammer and released it.
Now, it drags the edge of the concrete on the way into the driveway. The exhaust appears to hang the lowest so when we take it to get aligned we might see about trying to tuck it up a little tighter.
Next on the list is the dash. Phew!
g36 monkey
g36 monkey
Orlando, Fl
g36 monkey
g36 monkey
Orlando, Fl
So, after lowering the front, the car was just a bit too low to comfortably drive, well, anywhere. So the best cost option for front coil overs seemed to be QA1 so:
Also put spacers on the front wheels to help it look a lot better. And here’s how it sits after an alignment:
If you read the house build thread you’ll know what the deal is. Not sure if I’ll be able to do updates on here or not, but hopefully you’ll be able to see the dash repair, and eventually a clutch, fuel pump and rear end build. We’ll see.
Makoto
Houston
man i almost went F body route before i started my cobra build. these trans ams are just so much murica its crazy. they're just over the top in every way and i love it.
joemomma
I've always had a soft-spot for that era T/A, especially WS6 models. The market for them has gone crazy too, and finding a clean one is near impossible any more.
RAU03MACH
NEW MEXICO
I do like the Trans Am
But when Gm dropped them
I decided not to get one , parts is major problem
And you have to make shit work on it
I still think camero should have been dropped
