331 95gt 5 spd
DaMuuule
Hey there guys, need a little it of input from yall. looking at a car right now and not sure about what it should run. its a 95 gt with a scat 331 stroker assembly, i belive compression is around 9.5:1, Pro Topline 180cc heads a small comp cam ( around 520 lift ) trick flow track heat intake msd ignition 70mm tb and 80 mm maf
basic suspension stuff like bbk springs etc etc
transmision is a tremec 5 spd with spec stage three cluthch and 373 gears.
now im not a professional but i can hold my own in a car, with a good set of drag radials and skinnies what am i lookin at here?? my guess is somewhere in the 12.50 neighborhood but i could be way off. ive owned several fox bodies and 1 96 cobra but never an sn95 car with pushrods! ha! any help comments or concerns will be greatly appreciated.
thank you
IceMan
You re in the ballpark of what that car will run. Mid to low 12's taking everything is okay with the car.
