5.0 guys, what Oil filter do you guys run?
94gtstang50
I personally run the FMS FL1A filter, same one as on the foxes. Every once in a while I use the FL300. Is there any difference in pressure for you all?
HISSIN50
I also run FL1A's. Some filters dont well, filter as well, and as a result they produce a lower pressure delta. A more restrictive filter can show a little less pressure but can be doing a better job of filtering.
wytstang
FL1A only is one of the highest rated oil filters in well filtering.
94gtstang50
I personally like the FMS ones, you can get them at walmart too.
wytstang
Matt they sell FMS oil filters on the web site.
Ford tested their filter against the others,
Cut them all apart ect - It's at the top of the scale.
My friend - tech at ford for 10 yrs told me :)
94gtstang50
Sorry I was running the ford mtorcraft filters, not fms.
chickendreamer
K&N or the Factory Ford Ones (Motosport) - Now before anyone starts calling me a high roller from using a K&N, let me remind you. $15 for an oil filter is fuck all when you've sunk over $15000 into an engine.
DisturbedRacing
Another vote for the FL-1A or K&N. I also run a Ford or K&N filter on my PSD. The big block in the Chevelle gets a K&N.
94gtstang50
Decent, but it better to go with k&n, just changed my oil yesterday. Had mobil 1 in the gt and after 4000 miles, it was pretty black, that was using a motorcraft filter. We'll see how the k&n one does on there. Supposedly the oil looks almost the same as when it went in with this filter.
robtalbott
