89 block into my 95 gt
det_riot
Dearborn
Hey man, are you the guy i met on woodward friday? Regardless, yes it will fit in there. like we told you the other day, the main and most important difference is the timing chain cover and front accessories mount different. So as long as you keep your front accessories from your 95, you'll be good to go!
green5.0guy
green5.0guy
Harrison, Michigan, United States
yes i am i just wanted to make sure and im happy it will , the motor is just about ready to be sent out i just have to figure out what i excatly i want to do with it so tuesday im going to call around and arange it to be machined :)
castine917
wyoming, mi
block should have all the same dimensions. i am using an old 302 block myself. just had to do the front accessories and remove mech. fuel pump. i even used the 302 cam and firing order. needed to move injectors, plug wires, and tune but, it bolted in.
det_riot
Dearborn
i think he thinks that you had your block machined and if so where did you get it machined at?
