94 gt tach
jmahle67
hey guys so I bought a 94 gt convert and ive had it since september and fixed a lot of the stuff on it that needs fixed but now I am down to a non-working tach. It doesnt work at all. I tried running a jumper wire from the instrument cluster to the ignition coil but that was a no go. I figure the tach gets signal from the computer. What can I do to get it working? I am fine with running a new wire just need to know what to connect to.
DeepList
Auburn, IN
Have you tried a different cluster in it? If it's the tach itself that's broken, it may be easier to just get another cluster on eBay and swap them out.
whiplash473
Northern IL
op you're correct in that the cluster tach doesnt read directly from the coil like externals do......have you tried pulling the cluster and seeing if the tach needle is jammed? or if when you move it does it react the same as the speedo?
Musturd
Im thinking the tach broke as well and may be easier to swap out .
J
jmahle67
guys i did try a different cluster. was supposed to be from a 96. tach still did nothing.
DeepList
Auburn, IN
Have you tried to put the cluster into test mode to see if there's something mechanically wrong with the needle, or just the input signal?
To enter the HEC Dealer test mode, depress and hold the instrument cluster SELECT/RESET button, turn the ignition switch to the RUN position, and then continue pressing the SELECT/RESET button (5 seconds) until tESt is displayed in the odometer. The SELECT/RESET button must be released within 3 seconds of the odometer tESt display to begin the dealer test mode.
Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any stored continuous DTCs before proceeding to the next step. This way you can verify whether or not the cluster is receiving an input signal, and you can narrow out whether the gauge itself is bad.
(You can start the car while the cluster is in test mode and see the RPMs in the odometer window in number format.)
This may also help:
J
jmahle67
copy that, i wlll try the test and also see if i can find another cluster.
ProKiller
PA
what rz5.0 said. you need one from a 94-95 for it to be an accurate test.
J
jmahle67
so i wanted to update the thread for others who were wondering. I got the tach working. I got the idea when I took apart the instrument cluster and messed with the needle on the tach. I spun the part the needle sticks to a little bit. When I put it back together and put the key it moved slightly from like 1200 to like 1500 rpm. I then decided since I had another cluster I would take the tach out and swap it into mine. when i did it worked just fine! its a few hundred rpm off, but its from a 96 so idk if thats it or not but glad i got it working
J
jmahle67
how do i do that? when I put the needle back on i put on down at zero where the little stopper is
Goldmember
Cornwall, NY
If the '96 cluster was from a GT then the tach face is different, 8000 RPM tach vs 7000 RPM for the 5.0's. This might also be part of the difference.
rz5.0
Great state of TEXAS
Electronically they are different.. If you try to swap it as a whole it will not work. You can re pin and might work but not sure if it all works.. Never tried repining my self..
