94 mustang powerdyne ?s
94bluebyu
denver co
i have 94 mustang gt with 306 trick flow street intake gt40p heads stock cam and 9lb powerdyne
any sugestions for injector size 19s 24s 30s i have vortech fmu also
with msd btm do i need tune or has any1 had good luck w/ Bob Kurgans mail order tunes either way btm is hooked up
what r the best plugs to run and what gap
Any sugestions welcome thanks
Musturd
You can ditch the fmu get some 42's and upgrade the fuel pump 30's aren't enough . 30's are what you need usually for a healthy hci combo . I'm running 42's with 12lbs of boost with a aeromotive stealth 340lph
Musturd
Yea my car was dyno tuned previously as well . When nitrous hci . It's getting tuned again for the new setup
Win
Kennesaw, Ga
Would say 42 also... You can pick up a 340 pump for 100 bucks.
I have done a lot of research on the powerdyne lately as I found one ridiculously cheap that already had the belt upgrade and the billet impeller.
white95
Apex Junky
Prairieville, LA
with msd btm do i need tune or has any1 had good luck w/ Bob Kurgan mail order tunes either way btm is hooked up
You answered your own question!! Talk with Mr. Kurgan about this matter!! You're going to have to inform him of all your modifications before he can set the tune up anyway AND he's a Mustang-guru.
94bluebyu
denver co
thanks white 95
rz5.0
Great state of TEXAS
With the Dyne I bet 30 will be fine. . 42 won't hurt. The blower is not that efficient. But it's fun. I ran one years ago with 30s..
Nightmare
Cedarburg Wi
Kurgan is the man! He has tuned several cars up this way before he moves down south. Depending on where you are I could also recommend Mike Post Or marv at C&M Performance (MM&FF has used him before)
ivan12
+1 for Bob Kurgan although I can't comment about the mail tune aspect
94bluebyu
denver co
does any 1 know why i am in boost my fuel pressure dropslike 10psi new walbro255l new fuel injectors could it be filter bad or bad fmu or calibration of fmu
fiveohwblow
Unless you have the right disk for the fmu I would just dump it. Get the tune for it..
Exactly what he said. I dont think you can max out 30 lb'ers with a powerdyne. You might be at close to max injector duty cycle, but you should still be able to ditch the FMU.
94bluebyu
denver co
okay guys i bought new 36lb injectors they came with a c&l mass air housing and 36lb tube but no electronics will my stock electronics work??
heard the c&l can be hit/miss depending on the tune myself. I thought that was how they worked that you remove the tamper proof torx screws that hold the maf electronics to the housing and inser it into the new housing? I went with a lightning maf myself.
jeanfltns01
