95 gt help brake question
tommybunz
everytime i press the brake i hear air until i release the brake i went under there and it feels like its coming from the 4 holes on the brake booster where the rod and boot are located
GDTrumbo
Nashville, TN
I think the brake booster's diaphram has bought-the-farm. You should be experiencing an idle change as this would be a vacuum leak.
Have you experienced any unexplained brake fluid loss?
GT
95-stang
Does sound like the brake servo has had its day, any leaking air is a bad sign.
The booster can be shot without any loss of fluid at all.
2slo95fiveoh
Lawrence, Kansas
X2.. In fact, unless there is a severe Primary Piston cup leak in the Master Cylinder, there should zero brake fluid
inside the Brake Booster. You are probably experiencing a High and Hard brake pedal if your Booster is broken.
