everytime i press the brake i hear air until i release the brake i went under there and it feels like its coming from the 4 holes on the brake booster where the rod and boot are located
X2.. In fact, unless there is a severe Primary Piston cup leak in the Master Cylinder, there should zero brake fluid
inside the Brake Booster. You are probably experiencing a High and Hard brake pedal if your Booster is broken.
