95 v8 swap
Jcw4793
I have 2 95’s and one is a v6 shell, just missing the motor and trans, and a complete 95 v8. Im v8 swapping the v6 shell, which brings me to a question to be clear on. What all would be needed from the v8 shell to be transferred to the v6 shell?
tvsn95
whereas I have NOT done this particular conversion, it seems that you just pull all engine wiring with ECU and install into the V6 car.
That seems obvious BUT I would study the connector at the firewall and see what needs to be added for the internal wiring. you MAY need to add a wire or two or swap out the internal for the additional injectors.
I have done several Fox car swaps and they are VERY year specific in the wiring department.
My first guess is it will be simple.
Jcw4793
Jcw4793
I keep running into the saying that were all the same in 94-95, besides the engine wiring and such, but i keep finding differences in the two. Maybe because the v6 is base but the v8 is mach 460, with power doors locks and rke?
apsmith49921
The v6 car is only wired and ecu supported to fire 6 injectors and plugs not 8. That's why people say wiring and ecu
Tony SN956
