96 Cobra H pipe remove
Limey
Hi Guys
I am removing the H pipe on my '96 Cobra and I am having trouble getting a socket on the passenger side lower manifold to H pipe nut. I have removed the other 3 but I have broken a socket UJ trying to remove the last one. Is there a way of either raising the engine or dropping the sub-frame to get a straight access to the nut?
Bruce
cwgu3
You get the top starter bolt out by going in from the front of the motor mount. I use a 10" and 6" extension with a 13mm shallow socket .
As for the manifold nut, if it doesn't turn try heating it 1st then use a shallow socket with a swivel.
Staff member
A shallow socket is normally too short. You need a mid depth, 6 point, impact, 18mm socket. Then a good universal swivel and a long pull handle. You can get it. If not, it’ll break, and then you just start with the next phase of repair.
L
Limey
Thanks for your replies guys
You have confirmed my own thoughts. I just didn't want to carry out any unnecessary strip down.
