97 Cobra Speedo Issue
BillG
Hickory NC
Guys I have a friend of mine who owns a 97 Cobra. The speedo gears have been replaced and the speedo isnt working. How do we check the sensor on the transmission. Ive read you can check it with an OB2 hand scanner is this true. Any info would be awesome. I know how i fixed it on my 95 but our clusters are not interchangeable with out wire flip ive heard.
Thanks
BillG
BillG
Hickory NC
Really not sure what he has checked. I know he has sent the cluster to local guy we have that works on them and brings them back to life. I have a 94 - 95 cluster i want to take down and swap out for testing as well. I know the fuel and temp gauge wont work but the speedo should right? Just making sure its not cluster.
07GtS197
Fort Myers, Fl
Hmm I would still check all the fuses and grounds. I’m not sure you can use another cluster in it because pats is built into the cluster.
evilcw311
Most Evil Member!
Louisville, KY
Can’t use a 94-95 cluster in a 97. Totally different.
BillG
BillG
Hickory NC
Thanks guys for info. Here is what I have found out from him so far. Cluster gears replaced and cluster checked out. The sensor was checked and also was told it was good. SO either the fuse is issue or something isn't right. I'm still learning these cars with the journey I'm having with mine so thanks again for the info.
07GtS197
Fort Myers, Fl
Can he datalog? If so, he should see if the speed shows up on a datalog. If it does it’s the speedo. Otherwise did he do anything to the car before it started acting up?
BillG
BillG
Hickory NC
Im sure he has no idea what datalog is. All I have is a hand held OB2 scanner to check stuff with. Not sure that would even help
07GtS197
Fort Myers, Fl
It depends on what the fault is. If its the vss/oss then it will throw a code but if it is the cluster then I doubt it.
BillG
BillG
Hickory NC
Well he isn't getting a code or at least he hasn't told me of one. So that leaves the cluster to be the main culprit it looks like.
BillG
BillG
Hickory NC
Here's the million dollar question. Can the PATS stuff be turned off in programming. He is going to get cluster refurbished by a local guy and he says his PAT light wont go out like it use to.
07GtS197
Fort Myers, Fl
Pats can be turned off but I’m not sure it’s something that just anyone could do.
