D Laf said:
aw damn i need to get better info sources! somone told me it was 6 haha....well....howw abbooouuttt the rear axle and stuff, will that do me any good at all or would you recomend just changing my gear ratio?
nope, its only 4. i installed an IRS out of an 04 cobra into my 98gt and everything bolted right up, just have to drill those 4 holes thru the frame and into the trunk, which i didnt do. i had plans of welding those brackets onto the frame instead, but i just havent gotten around to it (ps. those brackets have 4 bolts each, and our cars only have provisions for 2 of the 4 bolts per side. 2 go horizontally, 2 go vertically).
and actually none of the cobra stuff is any better than what you already have, aside from it being newer. both your 94 and the 99 have 28 spline diffs, so thats nothing. the gears, however, might be different. 99 cobra came with 3.27's and im not sure what your car came with, so you could just grab the gears off the cobra and install them in your gt. everything else is IRS specific so it wont work.
so how is this car totaled if the engine, trans, and IRS are all still good, yet you cant see inside the car? ???
