abs light on, car off.
sn95gtvert
Spokane Washington
just as the topic says when my car is off, key out, my abs light is on. once the car is turned on it turns off.
i havent pulled codes yet, but wtf... i barely caught it. shouldn't it turn on when the car turns on if somethings wrong?
Addermk2
This is not a normal issue... you are going to have to do your own investigative work on this one.
sn95gtvert
Spokane Washington
oh yippie now i get to chase ghosts in my car.... sheesh. at least its nothing important.
(insert shoots self in face smiley here)
Addermk2
i'd start by unplugging components of the ABS system, and checking our wire harness for any places that it may be chaffed, or snagged on something
extreme_21
Mtl, Canada
The ABS light in the cluster is powered by fuse 15 in the I/P fuse box, it's a 10amp fuse thats hot in Run and Start. Fused wire to the cluster connector for the ABS light is pin 9 R/Y wire, pin 5 is DK GR and grounded through the ABS module. There is a splice on the grounded side(from pin 5) that goes off to the ABS Diag connector.
If your ABS light is on with the car off, pull fuse 15, if the light is still on with the car off, wire from cluster connector is picking up power somewhere between the bulb connector and the fuse box.
..next is all you
sn95gtvert
Spokane Washington
holy crap.....
i wish i could have an answer as specific as that every time i have a question.
extreme_21 you answer is extremely awesome i will start digging into it on my next day off.
hats off to you.
thansk.
sn95gtvert
Spokane Washington
i will report back as soon as im home from work. spending 5 days 250 miles north of home, just installed a 3500 sq/ft sub floor in 9 hours. tomorrow will be the real work day.
i need a beer and some sleep.
extreme_21
Mtl, Canada
Hehe...I just replaced a ASM Transmission in a Aston Martin DB9 in 8hrs ..brews in deed would be good!! ;-)
