Abs light wont shut off
07GtS197
Fort Myers, Fl
Since I bought this car in august the abs light has been on. I recently bought an Elm327 wireless obd2 scanner to read the abs codes. Well it doesnt give me the option to check the abs system so Im guessing the abs module is bad yet my abs is still working. Also my tc light will be on but wont shut off when pressing the button and sometimes its the opposite. And one of my calipers is starting to stick so maybe thats whats causing it and I noticed today that my ebrake doesnt work well and the rear brakes will squeak if my stang is at an angle with the ebrake on. What do you guys think?
Sorry that was a loaded post but theres a lot going through my head right now and I just want to get to the bottom of this.
wmfateam
Gilbert, AZ
Usually only high end scanners and factory scan tools will read abs. I assume your talking new edge since you mentioned TC. On my 96, one of the ABS sensor wires had been rubbed by the wheel causing my ABS light to stay on. But I am unaware how the sensors function in the newer models. Also do you have brake lights? A bad brake light switch can cause ABS and TC lights to stay on and also cause cruise control to malfunction. And about the squeaking and ebrake, I suggest a full inspection of the under car.
Sent from my XT1254 using Tapatalk
07GtS197
07GtS197
Fort Myers, Fl
The Elm327 can read abs codes, a buddy of mine on modded mustangs showed me how to read abs with the same scanner and app. And yes its an 02 gt, I bet they work the same so Ill check the wiring just to make sure. Isnt there a way to adjust the e brake? I think I have to pull the center console and adjust a bolt? I replaced my e brake front cable in my 00 gt and had to do that but that was years ago. Also yes my brake lights and cruise control both work. Its pretty strange isnt it?
Cpotts13
Biloxi, MS
Funny cause I just had the same problem! Well kind of... Check each wheel sensor first. Generally from what I have read is that if the ABS light comes on when your moving but not while you are stopped then it is the sensors. If it is the TC module, it will comes on from the start and not turn off. The TC module is a super expensive part new. However you can have yours rebuilt, I will include the link. Removing the TC module is easy and dosent require disconnecting any hydraulic lines...
http://www.ebay.com/itm/ABS-EBCM-EB...id=100040&rk=1&rkt=4&mehot=pp&sd=121110825517
[video=youtube;sIOrklnT9AA]https://www.youtube.com/watch?v=sIOrklnT9AA&index=9&list=WL[/video]
07GtS197
07GtS197
Fort Myers, Fl
I really thought it was the tc module since they go bad so often on our cars but do you think it is even if my abs works? They are integral right? These wide array of symptoms just has me dumbfounded.
Ballistic
Oregon
Mine is always on, when i had it at the dealership getting some work done on it, one of my friends there thats a mechanic said to not worry about fixing it..
Staff member
All that stuff is for sissies! We don't need that stuff, or power steering, or power brakes, or power seats, just as long as we have a/c then its good by me lol.
07GtS197
07GtS197
Fort Myers, Fl
I just want to get to the bottom of this and have this damn abs light shut off. And Im just glad my ac is still working after 13 years on the road, If not Id die in this florida heat lol.
evilcw311
Most Evil Member!
Louisville, KY
One can simply remove gauge cluster and take out said abs light.
Problem solved, nothing more to see here folks.
Glad I could be of assistance. B-)
Cpotts13
Biloxi, MS
I did this when I first installed my o/r x pipe a few years ago.. Even passed inspection because the light wasnt on!!
evilcw311
Most Evil Member!
Louisville, KY
Not all Stangs have abs as it was an optional if light doesn't come on upon start up its probably just assumed it's not s factory abs car.
That would be my thought.
Cpotts13
Biloxi, MS
I meant i removed the check engine light cause by the o/r x pipe and still passed inspection..
07GtS197
07GtS197
Fort Myers, Fl
Thats what Ive been reading but apparently my abs still works. Ive tried multiple times to lock up my tires to see if abs is shut off yet I cant lock up the tires. My front calipers are starting to seize maybe that could be contributing to this? Theyll loosen up when you put a c clamp on them or give them a few whacks with a rubber mallet so Im guessing the slide pins are dry. Plus it sat for a few months before I bought it.
from6to8
I know an older thread but a car I bought in 2016 which has not been driven much over the years in fact since 2019 I just put a battery in and started and drove some the other day. Going thru and diagnosing some things before I take it down and do the 331, the speedometer wasn't working when I bought so messing with it again.
Worm gears are fine but the steppor motor is likely faulty. Anyway when I put my other cluster in from the wrecked 95 everything works fine but what's crazy is the ABS light is on. It's one on with the other cluster and I switched back and forth a couple of times to make sure. When the cluster was in the other 95 last in 2015 the ABS light was not on so not sure what's the deal. I wonder if the light in the gauge itself has an issue? It would seem like it might not work or show when you start the car if the bulb is bad........
if the light does not work the car will try to tell you by beeping for 30 secs after you start it. Take a close look at the connection in the gauges that the harness slides into and sometimes the copper traces will lift and move enough to make contact with the trace next to it, or far enough off that it does not touch anything.
from6to8
kool I'll check that and it is solid, not flashing or anything. I only drove a few miles though just to verify the tripometer was working fine but even when I start it and idle it's solid.
