Adjusting clutch pedal
Tommy92
Los Angeles, CA
Hey guys. After doing some researching online. I can't seem to find a decent guide on how to lower my clutch pedal. It sits too high above my brake pedal for my taste and would enjoy driving more if it was lower. I looked under my dash and saw a metal clutch quadrant so it is after market and I do have a clutch cable adjuster. Help with pictures will be most appreciated.
MIKE93SVT
you can't adjust the height. it's set from the factory on a pivot point. if you shimmed it down. you would have to play with an adjustable clutch cable and try to get full engagement and release with a shorter throw.
Addermk2
Adjusting your clutch pedal down would be a bad idea. You won't get enough pedal travel to completely disengage the clutch. Learn to deal with it.
Addermk2
no, you really dont. You clearly dont have a grasp on how the actual clutch system works.
