Mustanger
Here are the directions from the Raptor website...Not much help to this dummy...WHERE do I find all these wires or spots to connect into? I assume the Instrument Cluster Connector will be plugged into the back of my instruments where is the ignition control module? Is it easier to get to?
Ground will be easy to do but where did you all find a switched fused 12+ wire under the dash? Thanks....
1994-1995 5.0L:
Tach signal is at instrument cluster connector (C251) pin #7, tan wire with yellow stripe. It changes color to an orange wire with white stripe and then goes to the ignition control module (ICM), connector C115, pin #11.
1994-1995 5.0L:
