Air compressor messed!
LaserRed5.0
So my a/c compressor has been kinda moving but squeaking and going bad I guess... today when driving the car the pulley wont move at all and the car smells real bad. What could happen if I keep driving it? Can this hurt the performance of a car, when the pulley doesnt move at all? Also what size belt would I need to short belt the a/c if anyone can tell me, its a 95 GT. The a/c works good still which is real weird, can I get away with just putting on a new compressor or is there more to replace if I decide on keeping the a/c?
Thanks,
Mike
Spd0lit
SoCal
if you keep driving with that you could mess up your belt so i would take care of it asap.
BigTang
it sounds like the clutch isn't disengaging fully when the compressor cycles off so its burning up. its going to lock up and throw your belt when it burns up the compressor. pop the hood and start the car w/ the AC off when you start the car, then watch what the compressor does, the center should not move. then turn the AC on the whole thing should spin for about a min then the center should stop. i bet yours doesn't stop completely and just slowly turns. you can actually buy a clutch by itself, its a little tricky to set up because you have to adjust the clearance on it but its a lot cheaper than replacing the compressor and the drier and having it charged.
2slo95fiveoh
Lawrence, Kansas
X2.. My old a/c compressors clutch was so worn out, that with the engine running, a/c off, if i turned the a/c on, the clutch would lock
up the comp. and slow down the engine speed so much, it would shut the engine off. I would recommend you replace the compressor as a unit
rather than just the clutch, for easiness of installation. You'll need to discharge your a/c system, remove the serp. belt, disconnect the a/c
lines, and bolts to the bracket, and reverse.. i would also recommend replacing the serp. belt while it's off, seeing as how it
was probably rubbing against a stationary a/c pulley, wearing off some rubber, which could be the smell you experienced.
Win
Kennesaw, Ga
X3
I would also say just change the whole thing at once it will make it a lot easier for you. What i used to do at the shop i managed if someone came in i would discharge there system and then i would record the amount i took out and when they came back i would just put the R34 back in. Even if they didn't have it done at my shop i would rather do that then for someone to leak it all out into the atmosphere.
