Hey guys, I need a little help here. I still have the airbag light flashing from before. I did see on one of the other forums that this could be caused by a blown airbag fuse. Well, they were right there is a blown fuse, #4 10 amp for the airbag system. I tried replacing the fuse twice, but both times the fuse just blew right away. Has anyone experienced this symptom? I know the module or the clock spring could be the culprit, but I don't want to buy either one if they are not the cause. I have also read that the error indicates a low voltage to the airbag monitoring system. Is this just as simple as replacing the battery and it will go away? I have not replaced the battery in a few years and I do not drive the car that often, so it could have a bad battery.
Any suggestions or advice would be appreciated.
Thanks!
Thanks!
