AmAlley27
OWNED ALL OF YOU JUST BY JOINING!!!
Ok so I finally have the time to make this thing. Some of you already know I'm putting nitrous on the Mach. I have a DynoTune wet kit that I'll be spraying a 100 shot with. I also have a WOT box, window switch, air fuel gauge, pressure gauge, the DynoTune control center, and the ZEX racers package or whatever. It has a heater, purge, blow down tube and pressure gauge which I'll be using the other instead.
So far the bottle is done and the line is ran for it.
The gauges are in and wired
The control center is in
The WOT box is in, I'll post a video as soon as I figure out how! I also change the spark plugs to NGK TR6 and I plan on taking to rear isolators out to help with the stance!
