Anyone who has installed a line lock...Help!
97blackgt
Bought a line lock but i dont have the correct fittings to tie into the abs pump (mine has the 3-channel bosch). How does everyone with the Bosch pump, work around it to make the line lock work? Can I put it before the proportioning valve? Or after?
Thanks in advance
stretch
well since you only want to hold line pressure to your front brakes it will have to be after the proportioning valve. I have never installed one on a vehicle with ABS, but If I was going to try I would splice it into the line after the ABS and before the front brakes. cut the line with a tubing cutter, slide a couple of fittings that fit the line lock over the lines and flare the ends of the tubing.
