ARP motor mount bolt (washer) questin?
BlkoutGT
MO
Hey guys, I just want to get this straight. Im installing MM solid motor mounts and Im bolting them up with new ARP bolts. My questin is the washer has a "beveled" (sp) side and a flast side, which side is suposed to sit against the head of the bolt? I assume the beveled side up, but I want to make sure. Thanks guys!
Paul
Does't really matter, but usually beveled size (where the stamping machine comes down to cut the washer out) should point "out" toward the head of the bolt.
BlkoutGT
BlkoutGT
MO
Thanks paul, I just re-read instructions for my head bolts and it says the same thing. :tongue3: I didnt remember that part :violent1:
BlkoutGT
BlkoutGT
MO
You are the king of blinging fasteners, so when I go to torque these down, on the pass. side the tab that holds the wire harness in place, on the ground strap on the driver side, those wouldnt through off the spec would it? or should a tighting the bolts just a pinch more?
Paul
It's not really gonna matter dude. Make 'em good and tight, and you'll be fine.
