August 2010 ROTM- *-ProKiller-*
atlanticblue98
Congrats to ProKiller and all the nominees, very close this month :thumbsup:
ProKiller
Engine:
-D.S.S. Super Pro Bullet 331 Stroker block with Series 20 upgrade
-Forged D.S.S. Pro-Lite Pistons
-Forged D.S.S. H-beam rods
-Cast Stroker Crank
-Cometic .050 head gaskets
-D.S.S. Windage Tray
-D.S.S. Main Support Girdle
-D.S.S. 7qt. Oil pan with FMS High Volume Oil Pump
-Vortech S-trim SQ-V2 (2.95" pulley)
-AFM Power Pipe
-Edelbrock Performer heads (1.90 intake/1.60 exhaust)
-Ford Motorsports 1.7 Roller Rockers
-AFM B-21 Cam (218/226 .542/.542 w/1.7 rocker 272/280 112 108)
-Edelbrock Performer RPM intake
-Stack Racing Polished 70mm Throttle Body
-Pro-M 80MM mass air w/ attached filter
-42lb FRPP Injectors
-Aeromotive Fuel Pressure Regulator
-PA Performance 130-amp Alternator
-Optima Red Top Battery
-BBK 1 5/8" ceramic coated long tube headers w/ Stage 8 locking header bolts
-Dr. Gas 2 1/2" x-pipe
-DynoMax race bullet mufflers
-Borla duul slant cut round intercooled exhaust tips for side exhaust
-255lph intank fuel pump
-T-Rex inline fuel pump
-MSD Pro-Billet Distributor
-MSD coil w/ Ford Motorsports 8mm wires
-MSD 6A Ignition system mounted in glove box
-Fluidyne Aluminum Radiator
-Manual Fan switch
-AFM PMS w/ boost controller
-Billet Smog Pump Delete (Dayton belt 5061015)
-Most wires hidden
-EGR Deleted
-1" intake spacer (waiting for install)
-Snow Methonal Injection Stage 2 kit (waiting for install)
Drivetrain:
-Tremec 3550 upgraded with 26-spline input shaft and larger output shaft
-Mcleod clutch
-Fidanza steel flywheel
-Maximum Motorsports Clutch Cable
-Steeda Double Clutch Quadrant
-Steeda Firewall Adjuster
-Pro 5.0 shifter
-Ford Motorsports Aluminum Driveshaft
-FRPP Driveshaft Safety Loop
-Hurst Line-Loc (Waiting for install)
Rear End:
-Ford Motorsports 3.73 gears
-Moser 28-spline axles
-Trick Flow Rear Stud Girdle
Suspension:
-Ford Racing Lowering Springs (I think C's)
-KYB Rear Shocks
-Cross Drilled and Slotted Rotors
-Steeda Aluminum Lower Control Arms
-Steeda Adjustable Upper Control Arms
-Maximum Motorsports 4-bolt Caster/Camber Plates
-BBK Strut Tower Brace
-Kenny Brown full length welded in subframe connectors
-2003 Cobra Rack (SPR-ZM)
Exterior:
-Fresh paint job :: Black with blue pearl, ghost blue pearl dual stripes
-Cobra R Hood w/ Hood Pins
-Roush Side exhaust side skirts
-Export horizontal tail lights w/ amber turn signals
-Ultra Clear Headlights
-Ultra Clear Side Markers
-Clear Rear Reflectors
-18 x 9 FR500 Hypercoated front wheels
-265/35-18 Nitto NT555 Extreme front tires
-18 x 10 FR500 Hypercoated rear wheels
-305/35-18 Mickey Thompson ET Street Radial II rear tires
-Window Tint
-Painted Red Calipers w/ Pony Stickers
-Silver Bumper Inserts
-Painted Mirrors
Interior:
-Painted Interior pieces
-White Face Gauges w/ LED light mod and red needles
-Sinus Industries Gauge Ring Bezel
-White HVAC panel w/ LED light mod
-Autometer 2 gauge pillar pod
-Autometer 2 gauge cluster pod
-Autometer 2 gauge clock pod converted for wideband
-Autometer C2 Boost, Water Temperature, Oil Pressure, Fuel Pressure gauges
-Autometer C2 Tachometer w/ UPR Tach Bracket
-AFM Uego 2000 wideband sensor (partially installed. Still have to hook up to Tach/PMS)
-Bullet Shifter Knob
-Billet Headlight Knob
-Billet Window Switches
-Billet Clothes Hangers
-Billet HVAC Contols
-Billet Cigeratte Lighter
-Billet E-Brake Handle
-Billet Door Lock Pins
-Billet Cruise Control Buttons
-AFM Billet Ash Tray Switch
-Neon Blue Lights under the dash on Driver's and Passenger's Side
-Aluminum Trunk Mounted Battery box (waiting for install)
Stereo:
-JVC headunit
-Pioneer Tweeters
-Viper Alarm
-Mach 460 Rear Deck Box w/ Amps (waiting for install)
got5.0
Atlantis
congrats man, well deserved! The front needs more lows, it looks higher than the rear in that pic
MadStang
Escondido, Ca
congrats man! well deserved and I'm glad my car lost since I feel it's unfinished lol.
:eek:ccasion14:
CompOrangeSN95
North Jersey
congrats man, I wouldn't have voted for you if I didn't think you had the nicest ride, and I have to agree with MadStang on the unfinished part, my car is a track car that happens to look good, your car is all around awesome.
