Auto to manual swap options?
Resol
I'm looking to do a auto to T5 swap in my my 95. I know the 94-95 T5 are longer with a smaller dia clutch and that i need the computer and all the other parts. I've even heard i can take the set up out of a V6 stang, with the V8 computer. Is this true? Also, could i pull one out of a fox body? 4 cyl, 6 cyl, V8? As long as i have everything, bell,clutch,flywheel,plate,trans shifter? I know i would need to modify my trans crossmember and driveshaft, but would everything work right with the 95 computer and pedal assembly? Any help would be greatly appreciated.
ram360
you can use a fox t-5 trans w/o modification as long as you use the fox bellhousing and a driveshaft spacer.
R
Resol
Thats the best news i've heard in weeks :) Wrecked foxes are a dime a dozen around here. I would still need the computer out of a 94/95 5 speed though right?
ram360
yea, I've heard the car would run w/ the auto computer but has some bucking and backfiring in between shift or something like that. Just get the 5spd comp.
