ball joints
ricansoulja69
hello, I have an 03 mustang and the ball joints where shot. I changed them but for whatever reason I can tighten the nut all the way to install the cotter pin by hand. Is this ok? This my first mustang and I've done ball joints in other cars and never had a ball joint that I can tighten down by hand. Has anyone else encounter this?
Thank
Silver95bird
Either there is dirt somewhere along the mating surfaces, or its not tight enough. I am assuming the ball joint is fully pressed into the arm until it was seated. This is not a place for shortcuts.
Sent from my moto z3 using Tapatalk
Check and see if the nut is turning with the stud prevents nut from tightening down
You could keep turning and not realizing the the whole stud is turning and it's not tighten up
The best way I found out to deal with this is to
Is to take a hammer and hit them in a little to seat inside the cone them start to tightening up the nut
They will tighten up once seated in the cone
R
ricansoulja69
thank you all for the great ideas, If I tighten it more it will go down below the cotter pin hole. I would have to get a lock nut to go down futher. I have to get a wheel alignment anyway and see what they tell me. I will let you guys know what they say. Thank you for your help. This is my 1st time owning a mustang so I'm learning. I used to be a chevy guy
alleghenyamerican
