best nitrous kit
gotnos
i got a 98 gt just an intake and underdrive pullies,i would like to go nitrous which is the best kit for the money any easy to install?
jfor441
They are all easy to install. Just depends on how much you want to spend.
I have NOS Dry system. Easy install.
MeanGrn Gt
ya exactly. best prices on quality stuff. not only are their kits good but they have goot tps/window switches, bottle heaters etc
Brian95SVT
Chesapeake, VA
Ok, first off I hate nitrous and wouldn't ever put it in my car but....
How exactly would it work in an auto?
I mean would I just spray and hold it and the car will shift gears so I don't have to let off or what?
I've heard stories of people blowing shit cuz they sprayed soo
jfor441
Not sure why you hate nitrous but meh...
As far as how it works, if you have a window switch it only allows the nitrous to be sprayed through a certain set amount of RPM's. If you have 3500-6000 RPM window switch nitrous can only be sprayed during during those RPM's. With an auto, if the ROM's drop below the bottom threshold of the window switch the nitrous will stop spraying but start back up when it gets above the RPM's.
The stories you heard from people blowing there motors is because their car was not running right. Nitrous is just as safe as blowers and turbo's. You have to have your motor setup properly for nitrous.
Brian95SVT
Chesapeake, VA
So I wouldn't have to hit anything, its like set to spray on it's on?
If not then I'd have to hit it between that RPM range?
Which one?
jfor441
There are a ton fo different ways to set it up. The window switch will not allow early activation. You can press and hold the spray button as long as you want but you are not going to get any nitrous until you reach the bottom threshold of the window switch.
If I was running a wet kit, I would get a separate 1 gal fuel cell and run race gas in that for the nitrous. I like my dry kit. When i get my new motor done I am going to be upgrading the solenoids to run a bigger shot of nitrous.
voidfinger
yea and most people blowing shit up either downshifted by accident or sprayed under 3000 rpm and it backfired.
I'm gonna be running the wet kit but on the reg 93 here in NC
voidfinger
my96gtstang said:
thanks jfor
didn't know it worked that way
but yeah
so if i hold on the switch it will never engage right
yea but thats why you get a WOT switch, so you don't have the f with it. So that with the window switch = you holding the stearing wheel and holding the gas down and not haveing to do anything but hold on and that helps times also.
jfor441
my96gtstang said:
thanks jfor
but yeah
as long as you are under the bottom threshold of the window switch then no.
Here is a good website to read up on Dry Nitrous kits. http://www.drynitrous.com/ Nitrous is best bang for the buck out there.
jfor441
voidfinger said:
my96gtstang said:
thanks jfor
but yeah
Yep forgot to mention about he WOT switch. That is also good insurance to have. Keeps your nitrous from spraying at anything less than full throttle.
voidfinger
my96gtstang said:
Didn't know there were all these settings.
Just thought you hit the button whenever you want it in and go from there
naw, thats like "o i just got this kit from this guy for like 100 dollars... then aboommmmm"
Brian95SVT
Chesapeake, VA
oh ok
hrm
well its just a personal thing, i don't really like them...
i mean i guess they aren't to bad now that i know all of that but i'd still never run it on my car
