Best PI intake location to purchase?
Tbuck07
joekd
Ct
Thats a pretty good price considering it's brand new, only parts not mentioned are the coolant tube and the water pump nipple which you will need for your non-pi car
GDTrumbo
Nashville, TN
This part can be had for $199. I think it's at A1 Auto. These Dorman pieces have integrated port o-ring seals. Real clean install.
GT
Willis_98GT
DFW Texas
i used that same ebay kit on a friend's 96 a while back, it came with everything, even the water pump nipple..
Wes8398
If you'd like to save some dough, buy the intake used from a classifieds section, Ebay, Kijiji, etc...
I got my PI cams and PI intake for $150 combined!! I think one of the parts came from this forum (cams?) and the other from Corral. I got all the odds 'n' ends from Randy Stinchcomb (sp?) for like $50 too.
greenscobie86
The Big Apple
There is a kit on ebay from a seller called custom mustang of florida.
Its like 299 but it has aboslutely everything you need to complete the job....
It even comes with the RTV sealant you need to "adjust" the coolant passages in the NPI head...
I bought it like 3 months ago and it was absolutely the most compelte kit ever! The seller even threw in brand new injector O-rings...
ALso the mani you mentioned doesnt come with a 2nd hole for the coolant crossover, the one I got does... (Not a problem if you have your own tap and die, but Im just saying)
T
Tbuck07
Sorry Id rather go new, and I already have hitech stage 2 cams. I'll just end up doing this kit, or the one greenscobie suggested
T
Tbuck07
Wait..how is the link I posted not a PI intake? Its off an 04 PI motor........
joekd
Ct
That is a PI intake, it's just not a Ford one, it's a dorman
You will have to drill/tap any PI intake crossover unless you have an aluminum crossover on your motor already with the dual temp sensors (if you have one of those you can just bolt it up but you wont have that unless your exisiting intake was replaced already) or the seller is doing the drill/tap modification for you
T
Tbuck07
Great 300 more dollars....(is half tempted to sell all his pi parts he has now....)
T
Tbuck07
Sorry just getting really anxious...So the one for 212 will be fine..just need to tap a sensor hole?
Wes8398
IIRC correctly, ANY PI intake will require the 2nd temp sensor hole to be drilled/tapped if it's going onto an NPI motor. It's really not a big deal man.
97GT4.6
Colorado
Yeah, the only way you can get around tapping it, is if you have a aluminum crossover already, and you can swap out the pi and npi crossovers.. that's what i did.
joekd
Ct
Tbuck07 said:
See your other thread, I just did the intake swap andf gave you some good answers there, dont feel like typing them again
