jedpony
On wot at full boost my dip stick pops out about an inch and leaks oil out and onto the header making a cloud of smoke as i drive. This is blow by correct? Would running a oil catch can and oil cap breather help this?
You need to change your pcv system!!!
PCV... get a piece for a turbo t-bird. Should help you out a lot.
Catch can.. Depending on your set up.
If you can get a non vented one.
You have to vent both valve covers and pcv on the back on the intake to the catch can the vent the catch can to the intake pipe right after the mass airflow sensor..
OR
Get a vented catch can run both valve covers and pcv to the catch can and plug the vacuim lines
Yea everything is still hooked up. I need to locate a diagram and just re-run everything
