Bolt-On Bullitt, one run from the track.
Bullitt5339
Full suspension, gears, 3300lbs, bolt ons, tuned, stock replacement longblock, stock intake, stock throttle body, stock cams. Car made 266rwhp/306rwtq.
[email protected]
The good: A new best time for me. The new suspension seems to be working well.
The bad: Trac-Lock was shot. One wheel tire peel as you can see in the video, so I had to launch at 3600ish rpm instead of my typical 5500rpm. I was also running Nitto 555R's for this pass, no aggressive tire compound on the car. The car should be capable of 1.6 60ft times, but this run was a 1.82 because of the problems.
The better: New fully built rear end with 4.30's will be ready to install on Friday... :headbang:
http://www.youtube.com/user/EdgarLopez#p/u/6/G8yeIIoGyIc
B
Bullitt5339
I think I fixed the video link. Try it again. It's a friend of mine's video he took of us racing at the track.
Inspector13
Nice run. :thumbsup:
What are you running for a suspension. Looked like if left pretty hard.
B
Bullitt5339
94 Cobra rear springs, UPR uppers and spherical bushings. MM lowers. Granatelli K-Member kit with 150lb coilovers and Strange adjustables all the way around.
B
Bullitt5339
Thanks for the videos Will.
We're going back out on July 8th, they're finally switching to night Test and Tune. You should come out again.
