Bolt on Timing upgrade for less than $100!
TT94SVT
When Boosting your car or adding nitrous controlling the timing is critical to keeping the block in one piece.
A crankshaft trigger wheel is the most accurate way to track the crankshaft. DIY fabrication of a trigger wheel may require you to space out all of your pulleys. However there is a fairly cheap bolt on option for our cars.
1996-2001 v8 Ford Explorers Have a 50oz harmonic balancer that bolts on directly and requires no pulley spacing.
I picked this one up at a local yard for $40
I used a masterpro crankshaft position sensor
$18
3D print PTEG Filament bracket
$0.50
Optional Ford Explorer timing cover has the sensor already mounted can also be sourced for around $40
Step 1 Remove stock balancer
Step 2 Install new balancer
Step 3 install bracket or optional timing cover. If needed I can send you the STL file for 3D printing which works with the master pro sensor.
Step 4 wire sensor per your ecu or ignition module instructions
Step 5 measure for a different size belt. Sorry I do not have a stock accessory configuration so I can not give an exact size. If someone else finds out I will update.
evilcw311
Most Evil Member!
Louisville, KY
Glad to see it bolted up with no issues. This will make it easy for a lot of guys going forward with big mods on the pushrods.
96blak54
Staff member
Lawrenceburg Kentucky
Crafty idea! Excellent resourcefulness!
Too bad them pushrod engines become boat anchors beyond 400hp....he he he
T
TT94SVT
I think the crank and the heads are the weak point. I’ve bent both the factory crank and gt40s but my block has not split
evilcw311
Most Evil Member!
Louisville, KY
Plenty of people have dailied 500hp 5.0’s with no issue. As tt said, it’s all about tune
