boosted 2v question
black96gts
ok guys took the car to the dyno to get it tuned .. it made 328 rwhp and 216tq at 4000 rpm 10 pounds of boost with a p1 procharger .. it made 328 at 4000rpm because of the stock fuel pump .. now the question is a walbro 255 pump can handle 400+ whp ???????
blown98gt
yes it will, not sure what injectors you are running but you'll need atleast 42# injectors
B
black96gts
im running 39 injectors fuel pressure regulator and a mafia,, but my tuner told me i need two fuel pumps ....
blown98gt
yeah i'm running a 255lph pump, kb bap, AFM inline pump, upgraded fuel lines, with aeromotive rails and 69# injectors and i am running in the 700hp range
IceMan
255 intank and you will be fine... You dont need twin pumps for 450 whp...
justinschmidt1
black96gts said:
so a walbro 255 its good for 400- 420+rwhp ?
My walbro intake maxed out at 5,000 rpms and my car makes 385 rwhp through a stalled auto.
but generally a 255 should be good for over 400 rwhp
mine just sucks for some reason
B
black96gts
385 rwhp justin ? how many pounds? also i dont know why it made 216 tq i think thats to low .. the tuner didnt know it was a 04 pi engine he thought was a 96 engine so he will have to make a new tune and with the new pump he said i will be over 400rwhp at 10 pounds .. i dont know what do u guys think ???
Mustang Mark
really 216? i just thought that was a misprint.. i would think it should be at least in the 360 range based on your hp numbers...
B
black96gts
ok the car dont really have a tune . he just made a program so the car can run with the 39 injectors and put the car on the dyno .. the first pass on the dyno it made 328 and 216 at 4000 rpm
justinschmidt1
im running 11 psi, intercooled, long tubed, o/r h, 04 pi engine, but you gotta understand this is through a stalled auto, aka biggest power robber in the world and the pull stopped at about 5500
Tuner sounds like a tard by that comment just so you know.
Dont understand why it needs a new tune for a pi engien vs a npi.
You would think the npi tune would be more aggressive as far as timing with the lower compression ratio and the a/f ratio is all measured and regulated by a sensor so again the motor isnt a reason for him to make a whole new tune.
dyno numbers can be manipulated on most dynos....so he can easily take your car from 380 to 400 rwhp if he wants.
but 10 psi with a manual should be around 400 or so rwhp
Slvr2000
I realize this is my first Post but though I'd throw my two cents in... i have a 2000 GT, running a Vortech at 11psi, Full bolt on car long tubes etc..(T-45). I went with the single pump out of the Ford GT, Comparable to a 255 if not a 255. I made 427rwhp and 412lbs of Tq.
The 255 should carry you over 400 easy so no worries there. :) 42lbs injectors is a better idea over 400 RWHP I'd think.
justinschmidt1
^ the GT pump is supposed to be good for like 285 lph or 310 lp ive heard....
either way everycar is differant, only way to tell is to dyno it and see what it does.
Like I said my setup should be good for close to 475 rwhp I would think but Im running out at 385.
