Pitbull_SN95
Well this is my first time building a modular engine, but I have built a few pushrods.
I started collecting parts about year and a half ago. I was going to just do a H/C/I swap initially, but I always want more. I ended up deciding on building a FI engine, and going with a turbo. Here's the build list.
Aluminum Block
- Cobra Crank
- Forged Rods and Pistons
- 2v/4v Melling HV/HO Billet Gear oil pump
- Moroso 8qt oil pan
- Moroso Windage Tray
- ARP Main Studs and Head Studs
PI Heads
- Stage 2 MHS Turbo Springs
- Stock Cam
- BBK Longtube Headers
Fox Lake P51 Intake
- Mild Port
- Cooling Mod
- Dragon 75mm TB
- JLT CAI
- Cardone Select Perf MAF
Meziere Electric Water Pump
Fuel System
- A1000 Fuel Pump
- 24lb injectors
- Aeromotive Fuel Rails and FPR
- -10 Braided Tank to Y, -8 Braided on Rails, -6 Braided on Return
UPR Tubular K member / A Arms
AEM Electric Digital Water Temp, Oil Pressure and Fail safe W/B
Bama SF3/X3
**Turbo System**
- 80lb Siemen Deka Injectors
- MP 68mm Turbo
- Canton Oil Relocation Kit
- MHS Stage 2 Turbo Cams
I haven't decieding on which to go with. I might just spend $2200 to get the on3 kit, and use my turbo (MP 68mm), or have a local shop fab a kit for me. Suggestions are appreciated!
Aluminum Block
- Cobra Crank
PI Heads
- Stock Cam
Fox Lake P51 Intake
- Mild Port
- Cooling Mod
- Dragon 75mm TB
- JLT CAI
Fuel System
- A1000 Fuel Pump
- 24lb injectors
Bama SF3/X3
**Turbo System**
- MP 68mm Turbo
